What should I do?
Old Apr 30, 2011 | 11:59 PM
slow78z28's Avatar
Default What should I do?
So I ended up dynoing my car today and made 405HP and 366TQ.
Now the horsepower bug bit me right in the *** after this and now Im thinking should I go with stroking out the ls1 to 408/427? or just saying **** it and go with something a little bigger like a 6.0l longblock etc?
Trying to figure out whats going to be the best bang for buck while reaching my goal of 550 to the wheels NA(i know expensive), and being a little reasonable with price... Open to suggestions! Thanks all!
Old May 1, 2011 | 12:15 AM
tnmotown's Avatar
I believe you can only stroke a ls1 to a 383. If you want a 408 you will need a 6.0 block to start. Now trying to make 550 to the wheels is gonna take a lot of money if you want to all motor. You can always just do a 383 with a decent head/cam and be around 450-475ish rear wheel, then throw on a 100 shot and be done
Old May 1, 2011 | 07:49 AM
slow78z28's Avatar
You know how it is. you reach your goal and then you want more :X
Old May 1, 2011 | 10:00 AM
cookba's Avatar
have a sponsor build you a nice 402 or 408 bottom that you can use your current heads on, maybe a little reworking and a larger cam. then like said above, throw a little spray and be done!. hell get the bottom end built stout enough and you could put a 200 shot through it.
Old May 1, 2011 | 10:38 AM
WS6tx's Avatar
you'll need a LS2 block or LQ4/9 block to go 408. Then put a set of cnc ported Ls3 heads and top end, a stout cam and you should be there. Either that or build up a 427 and you be there easily. Or the quickest way for you would be change your rod bolts to ARP2000 and slap a 150 shot on it. Good luck, let us know what ya plan to do.
Old May 1, 2011 | 11:05 AM
brian_rs/ss's Avatar
78mm plate kit and a 9".
then when it's time for a new bottom end grab the TSP 383 stroker kit. it's around $2k.
Old May 1, 2011 | 03:08 PM
slow78z28's Avatar
Ive been wondering how often people go with resleeving their ls1s now? though im sure that would cost twice as much if i decided to just go with buying a ls2 block and going from there :/
Old May 1, 2011 | 03:15 PM
1990LSx's Avatar
You can find an LS2 block at a decent price if you shop craigslist and the classifieds.
Old May 1, 2011 | 06:14 PM
WS6tx's Avatar
you can find a 6.0L block cheaper and easier then re-sleeving a LS1 block.
Old May 1, 2011 | 09:07 PM
s346k's Avatar
i believe an ls1 can stretch out to 393ci. however, if you are wanting 550whp n/a i'd be looking at an aggressive 408+ inch setup. you'll need an lq series engine (or ls2). lq4 would be the cheapest, as you will only reuse the block and possibly the crank.
Old May 1, 2011 | 10:28 PM
slow78z28's Avatar
i wish i could find a really good detailed book on step by step stuff like this :X a super manual
Old May 2, 2011 | 11:01 AM
slow78z28's Avatar
http://www.texas-speed.com/shop/item...d=708&catid=42
this is a nice block to start off at 454 dont you all think?
but then again a ls2 block off a truck stroked out would be the same..
Old May 2, 2011 | 02:51 PM
you mean an lq block from a truck?
Old May 2, 2011 | 04:51 PM
slow78z28's Avatar
sorry mean the lq9 too many things going around in my mind :X
