Another newb question - writing on my crank???
Is that stock? There are markings on all 8 rods too. It makes me feel like my motor's been opened. Plus the fact, one side had NGK plugs while the other had AC Delco's. Same side that had NGK's also had what appeared to be a shiny new fuel rail, while the other side was dirty, slightly rusty on the endcap, and corroded bolts holding it down. There is a green line drawn on my map sensor, and one of the hold down tabs is broken. Any idea's??
Dirty/rusty fuelrail and bolts:
Clean, shiny fuelrail and bolts (hard to tell, but this one was taken before I cleaned the engine):
And MAP sensor:
Don't know whats written on the crank, it's covered with plastic at the moment. But is it normal to have writing on the crank from the factory? I've never seen that before from any manufacturer. And the blue lines you can clearly see in the first pic on the rod cap.
Sometimes you never know; same with buying a car. It could be stock as a rock but the previous owner could have raced and beat the **** outta it and swapped all the parts back and cleaned her up.
What do the pistons look like?
Underside of the pistons look shiney?? Still, I can't figure out why the writing on the crank. Can that happen from the factory?
I can't make anything out on it. So, this motor's probably been rebuilt then? If thats the case, are there any numbers I can use off the block or trans that will get me any kind of dealer or warranty service info? Maybe I can get lucky and it was rebuilt at a dealership under warranty, and I can find record of it? Guess I need to try calling the junkyard and see if I can get the VIN from the truck it came from :/
So it is possible this was written on from the factory? That just seems so weird, idk. I've torn apart quite a few euro and jdm engines and enver seen that.
