Replaced Cam, Now misfiring
Old May 6, 2011 | 04:43 PM
98LSGun's Avatar
Default Replaced Cam, Now misfiring
General Question. I went with a pretty radical cam on my ls1 z28, Ls6 intake 42lb injectors, etc,, Started it up after the install and car will not idle at all on its own. which i kind of expected but if applying throttle car will run. had my tech throw a scanner real quick and getting multi misfires across both banks, Is this usually typical before a proper tune is performed??? to smooth out air/fuel and timing
Old May 6, 2011 | 04:51 PM
VandykeT/A's Avatar
I'm gonna say its normal since its untuned. espescially since you added bigger injectors.
Old May 6, 2011 | 06:06 PM
garygnu's Avatar
could be loose grounds or plug and wires.don't run it with out a tune with those big injectors.
Old May 6, 2011 | 06:18 PM
mattster03's Avatar
um yes... stop running the car until you get it tuned for the injectors.
