Rebuilt motor zero oil pressure help!
Completely rebuilt lq4 shortblock
Slp brand new oil pump (bought it off craigslist)
Brand new turbo cam
Turbo kit
The truck started right up but had zero oil pressure. Here is what we have tried already
1. Oil in the oil filter when we put the motor in.
2. We primed the oil pump with lithium grease in the oil pump. Didn't work
3. Put a quart of oil oil underneath the screen and the oil pump sucked it up but still no oil pressure.
4. We also tried disconnecting the injectors and coils and cranked it to see if it would self prime and it didn't work either.
5. We have already pulled the pan off to see if the crank is turning the oil pump and it is.
6. Disconnected the oil line for the turbo to see if any oil was coming to the turbo and nothing!
You guys have anything in mind?
"Put a quart of oil oil underneath the screen and the oil pump sucked it up but still no oil pressure."
That tells me the Oil pump is working. What about that plastic plug in the rear of the engine for the oil galley ?
When you let the oil pump suck up that quart, Where did the oil go?
If there was oil coming from inside the rear cover, behind the rear main cap, has to be that plug.
