help!!!
Old May 7, 2011 | 08:34 PM
Blown02Camaro's Avatar
Default help!!!
Iv got a 383 stroker ls1 I had built back last summer. The shop I had do the work is a gm specialist. After i had broken in the car, I had noticed that it was having to keep adding oil every two days. So it went back had a catch can put on after they found out the cam destroyed my pcv system. When i picked it up after the fix the shop said expect to keep using about 1-1.5 quarts of oil per oil change. Does this sound right to keep using that much?
Old May 7, 2011 | 08:59 PM
mark21742's Avatar
No... maybe alitttle bit, but that is using way too much oil
Old May 9, 2011 | 06:44 PM
Well the motor is set up for boost with a steal top rings. If that changes anything
