Pushrod lenghth ?
Old May 10, 2011 | 06:00 PM
Quick99TransAm's Avatar
Default Pushrod lenghth ?
Setup is L92 Heads milled .025 GM hot cam on a 6.0. what length pushrod do you think it would call for.Have the tool coming to check just looking for suggestions
Old May 11, 2011 | 09:39 AM
Jon@Texas-Speed's Avatar
I would guess a 7.375 depending on the lifters you are running with it. However, I would spend the $20 on the checker and measure and erase any doubt about it.
Jon
Old May 11, 2011 | 05:08 PM
Default Lifters
Running stock lifters.I had to order another pushrod tool the marks on mine were almost gone and hard to see.I know I need a shorter than stock pushrod because the stock lenghth pushrod opens the valve when I tighten down rocker with number 1 at TDC and exhaust valve partialy open.
