resizing cracked-cap LS rods ?
Thanks!
Thanks!
By the time you resize the rod properly with the better bolts so you actually have a better than OEM solution, your within $100 of an aftermarket rod or less and the aftermarket rod has a much better ARP cap screw and better steel. Its alot stronger than an OEM rod, even the budget stuff thats out there.
Saves a bunch of time as well and thats worth $$$ also
Go aftermarket in this department (unless your racing in a class that prohibits that)....it just makes more sense
-Tony
-Tony
edit: nevermind that^ answered my own questions haha, would i need the .927" wrist pin rods or the .944" wrist pin rods, i would be reusing the stock pistons
