LS6 crank pulley installed
Old May 16, 2011 | 04:53 PM
clayp's Avatar
Default LS6 crank pulley installed
I installed an underdrive pulley on my new factory LS6 longblock. Tapped the pulley on with a rubber mallet and a block of wood enough to allow the old factory bolt to pull the rest of the way on. How likely is it that my new factory thrust bearing has been damaged? I'm freaking out
Old May 16, 2011 | 05:30 PM
01ssreda4's Avatar
Its probably ok but why did you risk it? Buy the installer the next time you have to do this
Old May 17, 2011 | 08:46 PM
Fastdriver1992's Avatar
its fine i've done this on 3 different motors and havent had a problem. people call me crazy but idc how ghetto it is because it works. if u say im lucky well 3 times is pretty lucky i guess
