Afr heads spring preassure
Old May 17, 2011 | 11:37 AM
98hc4mula's Avatar
Default Afr heads spring preassure
I have my heads at a machine shop and they told me that the spring seat pressure was 180 and it was very high at 600 lift. Something like 440 if I remember correctly.
What are they supposed to be for a hydraulic cam? They have the upgraded springs and the engine is a 408 w the 205 AFR heads.
Old May 17, 2011 | 12:06 PM
mark21742's Avatar
Sounds about right....to be sure, check with your can manufacturer
Old May 17, 2011 | 08:28 PM
vettenuts's Avatar
Sound a tad high as I thought the 8019's were around 155 on the seat. PM Tony Mamo and get the straight scoop from him.
Old May 18, 2011 | 03:01 PM
Tony Mamo @ AFR's Avatar
Flow Wizard
Should be around 160 or so on the seat at a set-up height of 1.790 - 1.800.....this should be a dual spring with a red stripe on the outer coils (our 8019 springs).
That's the spring you want and need to run with that head....the valve is 120 grams....its not a lightweight.
Some shops may have equipment that hasn't been calibrated in a awhile....I assure you the 8019 is not 180 lbs at the height its suppose to be installed at (technically thats 1.800 from AFR but +/- .015 is acceptable).
Hope this helps....
-Tony
