heads and cam parts question
Old May 19, 2011 | 11:16 AM
xtinctbird's Avatar
Default heads and cam parts question
getting ready to order the thunder racing head and cam kit with the patriot ls6 heads and the "TR TRuTorq" Level 1 - 219/224 .609/.604 115 LSA 1800-6500 RPM Power Band cam, I have a 2000 LS1 looking for good daily driver power with some oomph for track days, would the 59cc heads or 64cc heads be better and the pushrod choices are 7.375, 7.400, and 7.425 which pushrods would I need,also would I need to upgrade to an ls6 intake or fast already pushing my budget so the fast is out but might be able to swing ls6 if it's required, I called their tech line and haven't heard back from them thanks
Old May 19, 2011 | 03:27 PM
Patrick G's Avatar
LS1 Tech Administrator
You will like the street manners of that cam, but you may get used to the power and long for something bigger down the road. If you go with a cam that's in the mid to upper 220s on the intake/low 230s on exhaust, you will probably not get tired of it. Pushrod size depends on how much your heads have been milled, the head gasket thickness, and the lifters you run. Most likely it will be between 7.400-7.425".
Compression is your friend and higher is usually better (assuming your run 91/93 octane).
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 19, 2011 | 08:42 PM
xtinctbird's Avatar
appreciate the advice gonna go with the 59cc heads with the cam how much lift would be feasible before I start running into clearance issues
Old May 20, 2011 | 07:52 AM
Patrick G's Avatar
Your cam is at maximum lift when your piston is almost all the way down the cylinder. You get into P to V clearance issues as your piston approaches TDC. Too much duration & overlap will give you problems here, not lift. With a 59cc chamber, you probably don't want to go bigger than upper 220s on intake duration.
__________________
Old May 20, 2011 | 03:08 PM
Samer's Avatar
If you are looking into Thunder's TruTorq cams, and going with Patrick G advice, I'd really recommend their level 4 cam 227/234 .616/.614 115 LSA
I'm a big fan of that cam..... just if it had 111 LSA
However, it will still be a great cam for a daily driven car.
Old May 20, 2011 | 06:52 PM
xtinctbird's Avatar
I appreciate the input looking forward to a bump in power, gonna be driving this setup for another year or so until I get medically retired and moved once all that craziness is over gonna go alot bigger definately gonna hit you up for a cam the Patrick G
