What Size Cam on a 383 built..?
Regardless.. I was still going to have to get a re-build considering the 180k original miles.. and those damge parts.. IDK.. but always wanted to do a forged bottom end.. but got a good deal instead with a different guy on the 383 for 600$ difference. And that was the Main Reason of my Low buget 383 build.. lol.. not considering ALL the Extras i still need to spend-on.. Head bolts,High vloum oil-pump.dbl.roller timing chain,Gaskets, CAM & (kit), lifters, ECT.
Better flowing heads.. Maybe down the road.. unless i get a really good deal like the ones on Ebay i posted.. and if i do heads then might *** well the FAST as well.. BUT..!! Thats the main Reason of a Budget!!
In Regards of power band.. what ever good CAM Recommendations i get.. That would work best with my set-up now.. and hope to put out a lil. more Than what i had B 4.. Not LESS..!! LOL..
...!! THANX EVRYBODY FOR THE INFO. AND ADVICES..!!
You still need to tell us what you want out of the car... Does it need to pass smog, do you want a torque monster, more power up top, good street manners, drivability, nitrous in the future, does mpg matter, street use, track use, ect... Or how do you want the power delivery to be different from your last setup or do you want to keep it like that just with more power everywhere.
I've got a budgit 383 sitting in the garage for my friend that we will finally install next weekend. Much more mild setup than mine (ls6 intake, DRM cnc ls1 heads that I cleaned up, stock gears, 228 232 115 xer/xe lobes) Should have dyno results on that in a month or so. I'll be pissed if it doesn't make 440/440 or more.
"ebay unknow heads no flow data" you will end up spending more money
(Im with you on thiss ====> ms4 cam does the job right now and down the road it will benefit with better flowing heads giving my 383 more *****
Thanx for the Info...!! And keep me posted on Ure friends 383.. THANX..!
