Pushrod math.
Old May 31, 2011 | 01:15 PM
Kaane's Avatar
Default Pushrod math.
I just did a head and cam on this 2002 LS1 motor.
The heads are TSP Terminator heads milled to 60cc.
EPS 226/226 cam
New Ls7 Lifters.
Using a pushrod checker, I got 9 turns to zero lash. That would put it at 7.250
add 0.080 for preload that puts it at 7.33
So should I order 7.325 Pushrods?
Old May 31, 2011 | 06:19 PM
vettenuts's Avatar
Based on your measurements and desired preload, those should work.
Old Jun 1, 2011 | 09:31 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Sounds right to me! Did you check an intake and exhaust on each bank?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 1, 2011 | 10:23 AM
OldCobraGuy's Avatar
That is a ton of preload...
Old Jun 1, 2011 | 10:44 AM
You often times find them setup with around .100" out of the box from GM. Setting them up with about .050-.090" is fine
__________________
Old Jun 1, 2011 | 10:47 AM
I find that amazing. Comp recommends around .030 for their stuff...which really sounds reasonable to me. I wonder how much preload is available before the piston bottoms in the lifter bore? Worth measuring to find out. If the plunger is that deep, it makes me also wonder if that's why so many of these valvetrains are noisy with bigger cams.
Old Jun 1, 2011 | 10:57 AM
Keep in mind a Comp lifter is different than GM. Some of Comp's require very specific preload in the range of .002-.006", and thereby basically require adjustable rockers to setup properly. The GM lifters on this platform have been measured to have as much as .125"+ of travel!
__________________
Old Jun 1, 2011 | 11:44 AM
That is on a GM lifter Matt...
 Michael S. Palmer
Old Jun 1, 2011 | 11:48 AM
Right. Like I said GM lifters, which is what the original poster is running, have a very long travel. Comp do not all have the long travel, but some of theirs do too!
__________________
Old Jun 1, 2011 | 12:17 PM
PREDATOR-Z's Avatar
Matt is correct
Old Jun 1, 2011 | 12:53 PM
Kaane's Avatar
I did both heads, both intake and exhaust. All came pretty close.
Old Jun 1, 2011 | 01:05 PM
Good deal, just wanted to make sure you covered all your bases
__________________
