243's with out cam worth it? I have a set of 243's from a 05 gto. I was going to put them on my Z/28 with a cam. Could I put them on with the stock cam? Would it be worth it? I'll cam the car over this next winter. I have 8xx heads now. |
You can install them with the cam stock cam and still expect about 15hp or so in gains at the tires! |
Originally Posted by Matt@Texas-Speed
(Post 14987078)
It would benefit you to update your tune, but she'll run alright without. |
(Post 14987184)
Cool, let me know if I can help with anything! |
Some have claimed as much as 25 rwhp by switching from 853 to 243 but I'd bet they were cammed first.....BTW thanks Matt @ TSP for the gaskets and bolts....great service as usual !!! |
Originally Posted by A.R. Shale Targa
(Post 14988442)
to save yourself some work later on, figure out what cam you're going to be using, buy the springs you'll need and install them on the heads before you put the heads on. Lots easier to change them on the bench than under the cowl. |
Originally Posted by farmington
(Post 14990159)
I did the springs while I did the heads. However.. if you can afford it, buy the heads now and hold onto them until you can afford the cam too. I ripped my car apart last year now i gota do it again.. |
A good valve job and milling will yield an easy 20rwhp on top of a stock camshaft. |
Originally Posted by IRONFIST
(Post 14990554)
| All times are GMT -5. The time now is 10:28 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
