243's with out cam worth it?
Old Jun 1, 2011 | 04:14 PM
1gt2nv's Avatar
Default 243's with out cam worth it?
I have a set of 243's from a 05 gto. I was going to put them on my Z/28 with a cam. Could I put them on with the stock cam? Would it be worth it? I'll cam the car over this next winter. I have 8xx heads now.
Old Jun 1, 2011 | 04:17 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
You can install them with the cam stock cam and still expect about 15hp or so in gains at the tires!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 1, 2011 | 04:25 PM
1gt2nv's Avatar
Nice! I'd say thats worth it. Would I need to retune for the 243's?
Old Jun 1, 2011 | 04:39 PM
It would benefit you to update your tune, but she'll run alright without.
__________________
Old Jun 1, 2011 | 04:47 PM
1gt2nv's Avatar
Cool. Thanks. I'm going to order the head/cam-gasket/bolt kit from you guys. Great price!
Old Jun 1, 2011 | 04:52 PM
Cool, let me know if I can help with anything!
__________________
Old Jun 1, 2011 | 09:28 PM
A.R. Shale Targa's Avatar
Some have claimed as much as 25 rwhp by switching from 853 to 243
but I'd bet they were cammed first.....BTW thanks Matt @ TSP for the
gaskets and bolts....great service as usual !!!
Old Jun 2, 2011 | 09:16 AM
Glad to help! Thanks for your business!
__________________
Old Jun 2, 2011 | 10:31 AM
farmington's Avatar
to save yourself some work later on, figure out what cam you're going to be using, buy the springs you'll need and install them on the heads before you put the heads on. Lots easier to change them on the bench than under the cowl.
Old Jun 2, 2011 | 11:18 AM
Darkman's Avatar
Good point. Ditto on the lifters and lifter trays for that matter.
Old Jun 2, 2011 | 12:12 PM
IRONFIST's Avatar
I did the springs while I did the heads.
However.. if you can afford it, buy the heads now and hold onto them until you can afford the cam too.
I ripped my car apart last year now i gota do it again..
Old Jun 2, 2011 | 02:07 PM
Damian's Avatar
LSX Mechanic
A good valve job and milling will yield an easy 20rwhp on top of a stock camshaft.
Old Jun 3, 2011 | 07:52 PM
1gt2nv's Avatar
I already have the heads. When I get a cam, I'll send the heads to AI. They are also going to spec me a cam for the heads. But I just want to put the 243's on now. I sold my stock heads already. Just have to remove them now.
