Rear main seal change.. =(
Old Jun 1, 2011 | 05:26 PM
209SlowLS1's Avatar
Default Rear main seal change.. =(
Hello guys and gals, I currently have my transmission out due to clutch failure. My rear main has a leak so im going to replace it before I put the new clutch in but I was wondering if it is necessary to change the cover gasket as well? My car has 102xxx on it do you think the covers gasket will be alright?
Old Jun 1, 2011 | 05:51 PM
NVR_SPDS's Avatar
I would. why take the chance of it leaking. Your rear cover is also an oil passage,
Old Jun 1, 2011 | 06:14 PM
Duffster's Avatar
replace the rear cover gasket...
Old Jun 1, 2011 | 06:34 PM
209SlowLS1's Avatar
Ok so will I need the allignment tool? Have you guys done it w/o one?
Old Jun 1, 2011 | 07:14 PM
mark21742's Avatar
I have never used or seen the alignment tool...I would just start all the bolts before tightening them... I ended up just getting the lower gasket kit... it came with the pan gasket, front and rear cover gasket, front and rear main seals, water pump gaskets and a few others...its more money at once, but a lot cheaper than buying each individual gasket as you go....just use what you need now and put the rest on the shelf for later (when you do a cam swap and oil pump upgrade)
Old Jun 2, 2011 | 12:36 AM
209SlowLS1's Avatar
Sounds good, I was reading people use rtv gasket for the lower portion does this sound correct?
