Will this work? Lq9 build
Old Jun 4, 2011 | 02:38 AM
millerw's Avatar
Default Will this work? Lq9 build
Im looking to do a stock lq9 bottom-end, PRC stage 2.5 5.3 heads, cam and fast 90 90 setup. Im concerned about Piston to valve clearence... Im intrested in using either V3, MS3, or T-rex...... What would give me the best power and not have clearence issues? Thanks for any help
Old Jun 4, 2011 | 03:31 AM
bonethugluv's Avatar
Here is a good read that i found on here. They are different heads and intake but all a cheaper route i believe than going with the prc and the fast 90 if you havent already bought them.
Read when you have time. 20 page post with tons of good info.
https://ls1tech.com/forums/generatio...s-learned.html
