Transmission wont go back in HELP!
I had this problem once & it was 'cuz the dip **** trans re-build shop put a Ford input shaft in my GM Viper spec T-56. Other than that, can't help. It should go in.
but whichever it is, just make sure the motor and trani are tilted at the same angle, strap it to a floor jack and just slide it in there. Make sure the pilot bearing is OK, or that the converter is seated properly, and make sure the guide dowels line up etc.
Or maybe you need to take a break before trying again
