Post your Oil pressure
Old Jun 8, 2011 | 04:21 AM
wesam's Avatar
Default Post your Oil pressure
Post your oil pressure: (let us make oil pressure data base )
Oil weight : 0w-40
Oil pump : SLP oil pump
idle cold : 48 psi
idle hot : 40 psi
cruising : 45 psi
WOT: 65 psi
Gauge (Stock/mechanical/electrical) : VDO oil pressure gauge (electrical)
Old Jun 8, 2011 | 04:48 AM
itsslow98's Avatar
Oil weight : 5w-30
idle cold : 60 psi
idle hot : 48 psi
cursing : 45 psi
WOT: 68+ psi
Melling 10296 High Volume Oil Pump
Old Jun 8, 2011 | 06:13 AM
wesam's Avatar
Originally Posted by itsslow98
Oil weight : 5w-30
idle cold : 60 psi
idle hot : 48 psi
cursing : 45 psi
WOT: 68+ psi
How come that your hot idle pressure is grater than your cruising pressure ?!!
Old Jun 8, 2011 | 06:18 AM
mark21742's Avatar
Oil weight : 10w30
Oil pump : Melling 10296 hi pressure/hi volume oil pumpidle cold : 70 psi
idle hot : 45-50 psi
cruising : 50 psi
WOT: 75 psi
Pennzoil oil
Fram double guard filter
04 GTO A4, 93,000 MILES. 408 iron stroker with about 150 miles on it
Last edited by mark21742; Jun 8, 2011 at 01:03 PM. Reason: corrected auto correct lol
Old Jun 8, 2011 | 06:23 AM
s346k's Avatar
99 ws6, 95k miles, lid and muffler.
weight/type: 5w30 syn & wix filter
pump: stock
idle cold: 50 lbs
idle hot: 25-30 lbs
cruising: 38-45 lbs
WOT: 60ish
i think other info, such as mileage and engine mods, is helpful.
Old Jun 8, 2011 | 06:56 AM
Old Geezer's Avatar
15K, 6.0 LQ4.
Mild cam, no other mods.
10w - 30
55 cold start.
45 hot idle
45-50 hot at hiway speeds.
Stock, ported pump w/ stock spring, no shim.
Old Jun 8, 2011 | 09:52 AM
ShevrolayZ28's Avatar
He said cursing pressure, not cruising.
Old Jun 8, 2011 | 10:08 AM
redz_02's Avatar
Cursing? That usually raises my blood pressure not my oil pressure.
On a side note, how accurate is the stock Gauge?
Old Jun 8, 2011 | 10:57 AM
jmm98LS1's Avatar
oil weight: 0w-30 synth german castrol
oil pump: ported LS6
idle cold: 45 psi
idle hot: 35psi (at 210*F oil temp)
cruising: 45-50psi (2000rpm)
WOT: 65-70psi
gauge: stock
filter: k&n 2006
This is in an iron 6.0 block with .0022"-.0025" on the mains & rods and .023" rod side clearance.
Old Jun 8, 2011 | 11:05 AM
01ssreda4's Avatar
Old Jun 8, 2011 | 11:12 AM
DWake's Avatar
Weight: 5w-30
Idle cold: 45-50
Idle hot: 40 most of the time (started dropping to 25-30 after mobil-1 filter at stop lights sometimes, stayed at 45-50 w/ kn)
Crusing: 45-50
Wot: 60ish
Pump: stock as far as I know
Gauge: stock
Ls1 w/ 140k miles
Old Jun 8, 2011 | 12:56 PM
1SLwLS1's Avatar
Iron 408 w/ ~8K
Viscosity - Redline 10W-60
Cold Idle - 55#
Cold Cruising - 60#
Warm Idle - 35-40# (185-210F)
Warm Cruising - 40-45#
Hot Idle - 25# (230-250F)
Hot Cruising - 40#
Warm/Hot WOT - 55-60#
Melling 10296
Autometer Short Sweep Electric for Pressure/Temperature
Old Jun 8, 2011 | 02:19 PM
1981turbota's Avatar
oil weight: 10w30 mobil 1 with K&N short filter
oil pump: stock
idle cold: 55-60PSI
idle hot: 40PSI
cruising: 50PSI
WOT: 65-70psi
gauge: stock
On a stock long block LS1 with 120K miles
Old Jun 8, 2011 | 11:09 PM
itsslow98's Avatar
i switched them by accident. should be 45 idle, 48 cruising.
Old Jun 8, 2011 | 11:37 PM
sweet-94z28's Avatar
oil weight: 5w30 Valvoline Syntech
oil pump: stock
idle cold: 65 PSI
idle hot: 42-45 PSI
cruising: 50-52 PSI
WOT hot: 65 PSI
gauge: stock
Full bolt on LS1 that gets its *** handed to it every time I drive it with 71K miles on the clock.
Old Jun 9, 2011 | 12:44 AM
09camaro383's Avatar
Oil weight : 10w-30
Oil pump : Lingenfelter
idle cold : 65 psi
idle hot : 60 psi
cruising : 62 psi
WOT: 70+ psi
Gauge : stock
Old Jun 10, 2011 | 06:38 AM
wesam's Avatar
come on guys post your pressure
