lq9 bearing question
Old Jun 9, 2011 | 03:06 PM
xx_2000nbmSS_xx's Avatar
Default lq9 bearing question
i know all of the accessories from my ls1 will swap over just fine to my lq9 block. and all the gaskets are pretty much the same with the exception of the head gaskets.
but will ls1 main and rod bearings work on an lq9?i will be using a standard bearings
Old Jun 9, 2011 | 03:18 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Yes sir, they use the same rod and main bearings as the LS1/LS2/LS3
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 9, 2011 | 03:28 PM
Awesome thanks matt.
that will save some money right there. LS bearings are cheaper then LQ for some reason
now where can i get all the gaskets needed in one shot. i've looked at felpro and other brand but they are always missing something like the gaskets for the cam or rear main
Old Jun 9, 2011 | 03:45 PM
We've got the bearings and everything else you could possibly need to finish the project!
__________________
