Newb cam install question
Old Jun 12, 2011 | 10:09 PM
birdman2447's Avatar
Default Newb cam install question
I am in the middle of a 99 ls1 engine swap. The engine is out of the car and I was doing the cam swap this weekend. Swapping in a tru torq level 2 with springs, push rods, etc... Anyways I was following the writeup on ls1howto.com. I wasn't paying attention to the process and because i have rebuild many over head cam engine where the lifter wont fall I failed to either use a magnet or rod to hold them. I installed the new cam and then realized that i missed the step. Do you guys think I am good to go? As a check i installed the pushrods and they all sit at the proper heights. If a lifter was to have fallen down would it have fallen completely out so i would obviously know there was a issue, ie a pushrod would then drop down farther than it should. Any input would be great!!
Old Jun 12, 2011 | 11:19 PM
BrntWS6's Avatar
You should be able to look through each pushrod hole and see the lifter cup. The lifters sit in there pretty tight, which is why some people use the "pull and prey" method. You would definately know if you set the pushrods and they didn't fall...i'd say your fine.
Old Jun 14, 2011 | 01:46 AM
chrisfrost's Avatar
Ya You got lucky dude .
Old Jun 14, 2011 | 02:04 AM
z99ls1's Avatar
Restricted User
His engine is out anyway so it wouldn't have been to bad, but yea he did get lucky lol
Old Jun 14, 2011 | 02:14 AM
hookngo's Avatar
Real lucky
Old Jun 14, 2011 | 05:47 AM
J1D2warrior's Avatar
you should have heard it if one fell. and yes. if one had fallen it would have fallen all the way out.
Old Jun 14, 2011 | 10:24 PM
94mustang's Avatar
Sounds like your good to go, just don't do it again lol
