LS6 in my WS6?
Old Jun 20, 2011 | 03:49 PM
gs462's Avatar
Default LS6 in my WS6?
I'v tried searching and I cannot find a definate answer. I know that some of the later cars got LS6 motors, how would one be able to verify if they have an LS6? The intake has part # 12573572 which after searching here comes up as an LS6 intake. And my car was built in 05/02.
Thanks for any help,
Old Jun 20, 2011 | 03:50 PM
Schmalgar's Avatar
Some of what later cars? F-bodies? I don't think they did, did they? I know the GTO started as an LS1 then switched to whatever LSx... But I thought all 4th gen F-bodies were LS1s...
Interested to hear if there were F-body LS6s...
Old Jun 20, 2011 | 03:52 PM
Hashish's Avatar
The later cars didn't come with LS6 engines, but some did come with LS6 blocks. All 01-02 cars had LS6 intake manifolds. Your car should still have LS1 heads, pistons, and cam. As far as seeing if your car was one of the few with the LS6 block, I have no clue how to tell other than referencing the casting numbers on the block.
Schmalgar's Avatar
Oh yeah... LS6 intakes, I did know that! Duh moment
Old Jun 20, 2011 | 03:56 PM
gs462's Avatar
Thanks, do you guys know where I can find the block casting #s? is this what you need a mirror to see on the drivers side rear of the block?
Old Jun 20, 2011 | 04:02 PM
redbird555's Avatar
Yup an easier way to tell is look at the top of the block behind the water pump if you have an ls1 block u will have 2 bullseye casting marks on the corners if it's flat it's an ls6
Old Jun 20, 2011 | 04:29 PM
gs462's Avatar
Cool this i can check right now thanks again, what would the difference be from an ls1 to an ls6 block? stronger?
Old Jun 20, 2011 | 04:34 PM
gs462's Avatar
I have the bullseyes, so LS 1 it is. Thanks again.
Old Jun 20, 2011 | 09:14 PM
Steve01SS's Avatar
All 01/02 got the LS6 intake. Some 01/02 F-bodies got the LS6 block. No real gain though with the block. All got Ls1 241 heads and LS1 cam.
My block for my build is an Ls6 and came from an 02 camaro. My 01 SS also came with a LS6 block.
Old Jun 20, 2011 | 09:28 PM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
10% got the block in 2001, and 25% in 2002
Old Jun 21, 2011 | 10:10 AM
Rise of the Phoenix's Avatar
Good to know. My 02 WS6 has the LS6 block. Isn't the LS6 block stronger than the LS1 block?
Old Jun 21, 2011 | 11:10 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Old Jun 21, 2011 | 01:09 PM
20SOM01's Avatar
I read that there were no difference between the two, true?
Old Jun 21, 2011 | 02:58 PM
MasterTomos's Avatar
From what Ive read, the blocks are pretty much the same.
Old Jun 21, 2011 | 08:01 PM
Z28/2002's Avatar
From one of the sitckies, pics don't work though
https://ls1tech.com/forums/1740886-post8.html
Old Jun 21, 2011 | 08:05 PM
groundZ-28ERO's Avatar
awesome, i have no bullseyes and 243 heads, all i need is the ls6 cam and ill have an ls6, lol
Old Jun 22, 2011 | 03:13 AM
usafws6's Avatar
i installed an ls6 crate in my ws6. Best thing i couldve done.
Old Jun 22, 2011 | 10:07 AM
I didn't think ANY of the F-Body's got the 243 heads.
Old Jun 22, 2011 | 10:27 AM
redbird555's Avatar
They didnt, someone put the 243 heads on the car at some point in time. Also fro what its worth the only thing different with the ls6 block is that its supposed to be made of a better alloy, it has bigger casting webbing in the block to make it stronger, oil passages are better and the cylinder bay to bay breathing is supposed to be improved to help it rev high. However it doesnt do anything to increase power.
Old Jun 22, 2011 | 03:32 PM
BlackGasGuzzler's Avatar
I thought some later year cars got the LS6 block, but it doesn't really make a difference. If anything, it's not as strong as the LS1 for F/I. There is a bit of info about it in the FAQ section.
