how much to change a4 to a m6
Old Feb 27, 2004 | 01:48 PM
kevin02's Avatar
Default how much to change a4 to a m6
how much would it cost to change the automatic transmission in my 02 slp firehawk to a 6 speed?
Old Feb 27, 2004 | 02:28 PM
11 Bravo's Avatar
This is the wrong section for a tranny question, but I'll help you out. My car is in the shop as we speak getting switched to a T-56 (and 12 bolt). How much you spend depends on how good a deal you find. I bought a complete T-56 setup for $1800. It is newly rebuilt with a steel shiftfork and McLoed clutch, Pro 5.0 shifter, console, clutch pedal and everything else needed. My shop is charging $700 I think for the install, $100 to get my pcm reflashed for the T-56.
Old Feb 27, 2004 | 02:36 PM
Kevyn's Avatar
I would like to go from M6 to A4.
The part that stopped me was I didn't want to get into modifying my wiring harness and having to switch PCMs and lose my ls1 edit capability.
Maybe you will luck out and find someone near you, like me, that wants to swap the other way.
Old Feb 27, 2004 | 03:24 PM
Steve1969LS1's Avatar
You can even a new PCM reflashed with your old VIN number so you can use your LS1edit.. thats what I did with my 69 LS1 project..
Old Feb 27, 2004 | 09:41 PM
LASTLS1's Avatar
6 Second Club Moderator
I have a 2002 t56 with 5100 miles on it! Never broke, never rebuilt. JUST LIKE NEW!! Clutch, bell housing, shifter and master cylinder. PM if interested.
Old Feb 27, 2004 | 10:46 PM
z28hokie's Avatar
You have a pm...
