Please help me
Old Feb 27, 2004 | 11:36 PM
blacktransam's Avatar
Default Please help me
Well I put the new crank and bearings in tonight but i realized that the rod bolts are torque to yield as well as the main cap studs and bolts. So now i need more hardware (the local dealership loves me). My question is the torque spec and degree of yield for new OEM hardware. I got the torque sheet off LS1howto i just want to double check it.
All i know is when this is done the sexy black bitch better fly.
Old Feb 28, 2004 | 10:07 AM
crainholio's Avatar
You're building an engine without a Helms or some other spec sheet?? Wow....how do you know the bearing clearances, crank endplay, rod side clearance, etc are right?
Old Feb 28, 2004 | 10:19 AM
jrp's Avatar
jrp
SN95 Director
my thoughts exactly
Old Feb 29, 2004 | 06:37 AM
i have the spec sheet off of ls1 howto but i'm double checking it to know that it's right.
Old Feb 29, 2004 | 11:58 AM
SLowETz's Avatar
TTY specs are:
Main bearing cap bolts(in sequence)-
Inner bolts: Step 1.....15 lbs.ft, Step 2.....Turn an additional 80*
Outer stud nuts: Step 1.....15 lbl.ft, Step 2.....Turn an additional 50*, side bolts.....18 lbs.ft.
Connecting rod caps bolts or nuts: Step 1.....15 lbs.ft., Step 2.....Turn an additional 60*
Windage tray nuts: 18 lbs.ft.
You need a book
Old Feb 29, 2004 | 02:30 PM
yeah u'd think i'd have one since i work in an auto parts store. But they get bought up so fast. thanks for the info thats all i needed. When the rest of the bolts get here tues i'm putting this bitch back together
Old Mar 1, 2004 | 10:58 PM
crainholio's Avatar
Bookmarking this for the inevitable future "Why does my engine make a knocking sound??" post.
