Moly file fit ring for STD bore lq9?Ring gap??
Old Jun 27, 2011 | 05:54 AM
Dave_the_SS's Avatar
Default Moly file fit ring for STD bore lq9?Ring gap??
2 questions :
Where to get a affordable set of STD bore file fit moly rings for an lq9?
What should the ring gap be if the motor will be sprayed with a 125-150 shot?
Me and a friend are in a debate to put file fit rings in his motor or (he) wants to just use a oem ring cause he doesn't want to file fit.
Old Jun 27, 2011 | 07:12 AM
PREDATOR-Z's Avatar
https://ls1tech.com/forums/generatio...learances.html
