motor is in just a few things to fix now
After letting it run and get up to temp. I go to pull it in the garage very hard to get in gear. When I do get it in gear with the clutch all the way to the floor it creeps forward. Like the clutch isn't all the way in. Any ideas. Its the spec stage 4 clutch. didn't chang anything from last time. didn't even take out the trans.
Now to today. I put a new battery in the car because it died and didn't take a charge. i go to crank it nothing happens. The instrument panel goes crazy when I push in the clutch. It will not let the car crank or even click the starter. im lost on this.
__________________
As far as the battery double check your connections. A loose ground can cause all sorts of problems. There might have been a connection that was "just tight enough" and when you took the battery out the cables probably moved and now it isn't tight enough. Start with your battery cables on the battery, then grounds and I would also check it at the starter.
Hope this helps.
