Push rod length
Old Jul 7, 2011 | 09:24 PM
neals98's Avatar
Default Push rod length
Ok i done some seaching and i think have it but just want to make sure. Putting another set of heads and cam in car. I have a set of 7.400 push rods pulled them down to 0 lash then start my turns. I am only getting 1/2 a turn before they are tight. So from what i have seen i need 7.450 to have the right preload.
How does this sound?
Old Jul 7, 2011 | 09:49 PM
A.R. Shale Targa's Avatar
Most on here shoot for about .080 lifter preload for a moderately quiet
valvetrain. I believe that is around 1.5-1.75 turns from zero lash to
22 ft./lbs. rocker torque. Are you sure the one you checked had the
lifter on the base circle of the cam ????
Old Jul 7, 2011 | 10:26 PM
neals98's Avatar
Yes it kind of hard to check with the YellaT rockers but pretty sure it was right. I put the trickflow heads on that call for 7.500 push rods. The heads were cut down .030 I think the 7.500 is going to give way to much preload.
Old Jul 8, 2011 | 08:20 AM
vettenuts's Avatar
Counting turns with the YT's is not a good way to go because of the design. The first step should be to verify the wipe pattern as they "may" need to be shimmed. Once that is done, you can measure. Best way with the YT's is the adjustable pushrod so they can be tightened snug and use the adjustable to obtain zero lash and add preload. They rockers have to be tightened in pairs, so the GM procedure can't be used. You must rotate each cylinder to firing position then install the rocker pair while both lifters are on the cam base circle.
Old Jul 8, 2011 | 08:43 AM
neals98's Avatar
Ok thanks. I will try to get a checker.
I put #1 in firing position and slowly pulled both to 0 lash. Then started my turns. I done it about 5 times. Each time i came up with 1/2 a turn. From the seaching i have done .025 will be about 1/2 a turn. So 7.450 should put me at 1 1/2 turns.
Old Jul 8, 2011 | 08:48 AM
neals98's Avatar
http://www.ls1howto.com/index.php?article=21
I found this but they are talking about 1/4 to 1/2 a turn for preload. Are the turns diff for the YT rockers?
Old Jul 8, 2011 | 02:58 PM
vettenuts's Avatar
Do not follow LS1how to for YT installation, it is wrong.
Here is how to set up geometry, note this can be done on the car as well as off the car: Link
Here is how to measure for pushrods after geometry is set: Link
Old Jul 8, 2011 | 03:32 PM
neals98's Avatar
Ok thanks man i will let you know how it turns out.
