Anyone using 3/8" Pushrods?
Old Feb 29, 2004 | 08:18 PM
michael101's Avatar
Default Anyone using 3/8" Pushrods?
I have to order an odd length pushrod for my setup. I've found what I need, but it's in 3/8" instead of 5/16". I know the hole in the heads is 0.43 so it would fit.....but would it work?
Old Feb 29, 2004 | 09:45 PM
99 Black Bird T/A's Avatar
Probably will depend on what other parts you are using with the valve train. Which rockers are you planning to use?
Old Mar 1, 2004 | 07:19 AM
Old SStroker's Avatar
3/8 " are much stiffer than 5/16" of same wall thickness, and are used on aggressive/high lift/high rpm engines. If you make sure it clears everything it should work, but I'm surprised you can't find a 5/16" of the correct length. What length do you need?
Old Mar 1, 2004 | 07:31 AM
michael101's Avatar
I need 7.675 length. My heads are the LS6 style with Crane dual springs. I am setting up the stock rockers until I can afford to go to adj. shaft mount. I can get custom rods made, but it would be easier to order a stock item. I haven't found anyone with this length in the 5/16".
Old Mar 1, 2004 | 07:50 AM
michael101's Avatar
I found some 5/16" in the length I need from Trend Industries....great place.
