fast intake vers. ls2 90/92
Old Jul 15, 2011 | 09:35 AM
david vericker's Avatar
Originally Posted by redtan
Ok how about this one Dave:
The LS2 intake can be ported in 2 ways: porting the runners to match the heads and porting the guts of the intake to allow for more volume within.
Now people have ported the runners and gotten 5-10 rwhp. Then they ported the guts of the intake and got another 5-10 rwhp. Yet they did not touch the runners the second time, so where did this power come from? If what you're saying is true, as in you can cram as much air in the intake as you want, it's still going to be limited by the runners, then this idea would not work. But people have done it, keeping the runners the same size and shape, and only improving the volume of air in the intake and they gained power.
So the same works for the LS6 with the bigger TB opening. Sure that doesn't improve the actual flow thru the runners, but it allows for more air to enter in the bowls of the manifold that then is available for the runners to take.
Can't say that agree with what you stated,but you have a right to your opinion. Now if the method of porting the "guts" as you call it was actually that effective then wouldn't all of the major porters of manifolds do that as a standard practice on the FAST and LS6 as well? There comes a limiting point where porting is no longer going to be a benefit,but will actually become detrimental to the flow of the manifold,that's why it takes a expert porter to know where that line of limitation exists.
Old Jul 15, 2011 | 09:49 AM
PREDATOR-Z's Avatar
Besides volume one has to take into account velocity.
same issue when it comes to heads. many thought for awhile that larger runners meant automatic increase in power, while the truth of the matter, shape of runners and ability to increase velocity as well as volume is the key. That is also why not all valve jobs are the same.
Old Jul 15, 2011 | 09:50 AM
Originally Posted by PREDATOR-Z
First of all David, you're the one that came out talking smack because you simply do not understand it.
you're even unwilling to read info from people who have done it and seen improvements.
There was even way back an article in a magazine that swapped various TBs and intakes, the best (not by much) was a 90/90 FAST, then came TPIS 90/modified LS6, then oval TPIS TB with LS6, then just plain LS6.
There is plenty info on Corvette Forum as well.
BTW the graph above was from a stock internal Z06 and Crane 1.8 rockers (1.8 rockers were on before intake swap and after).
As I said I used a prototype BBK 85mm and my intake modified by TPIS and I saw a good 15rwhp across the curve. So it does work.
The purchaser has the right to make his or her own decision. If individuals out there think that this conversion is a viable upgrade then so be it. I personally can't buy it,but every cat has to swing his own ax.
OP,sorry for mucking up your thread...end of subject for me.
Old Jul 15, 2011 | 09:57 AM
redtan's Avatar
It's not really an opinion...I've been researching ls2 porting for a few years now since I got my gto and there have been plenty of people porting the bowels and gaining power without touching the runners. I don't know what the LS6 looks like inside, but the FAST does not have all the crap that the LS2 has.
Yes there is a limiting point to this, I agree there. But I don't think the limiting point of LS manifolds is 78mm and anything more than that is not going to really do anything.
Old Jul 16, 2011 | 12:01 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
What?
Old Jul 16, 2011 | 10:17 PM
garygnu's Avatar
consider some of the alum intakes that are 4 bolt design.you can get them for a good price and port them if you want.
Old Jul 16, 2011 | 11:19 PM
mark21742's Avatar
I love my ported Edelbrock proflo xt, but in my GTO all I had to cut was the hood
