408 vs 370 question
Old Jul 12, 2011 | 03:06 PM
b0b's Avatar
b0b
Default 408 vs 370 question
Its my understanding that if you take a lq based block and make a 402/8 that the piston skirt comes out of the sleeve at the bottom of the stroke, thus severely affecting the longevity of the engine. Is this true? If so how much can it affect the lifespan? Keeping the stock stroke and doing a 370 would eliminate this, correct? I do not want to spend the money if it wont last. Were talking abt a summer/good weather/weekend/occasional track use car btw..Thanks
Old Jul 12, 2011 | 03:25 PM
PREDATOR-Z's Avatar
One can remedy this issue by getting correct length pistons. In general 4.0 stroke or less is pretty reliable. There is however no substitute for displacement
Old Jul 12, 2011 | 03:29 PM
b0b's Avatar
b0b
Would you happen to know the length of piston that is correct?? Is that an issue that a vendor can help you make the right choice with when ordering (I hope!)?
Old Jul 12, 2011 | 03:33 PM
PREDATOR-Z's Avatar
Yes, I've used Ross pistons
Old Jul 14, 2011 | 05:22 PM
Texas_WS6's Avatar
If your vendor can not get you the correct pistons with the correct rod length, you need to find another vendor!
I too use Ross pistons. Nothing short of the best!
Old Jul 14, 2011 | 06:00 PM
trans_am7935's Avatar
the LS7 in stock form uses a 4" stroke. so if GM would do it, then i dont see a reason why you shouldn't do it!
Old Jul 14, 2011 | 10:29 PM
SOMbitch's Avatar
Wiseco also makes some excellent pistons for this application and has the largest selection of shelf pistons I have seen.
Old Jul 15, 2011 | 08:46 AM
redtan's Avatar
Well is the cylinder sleeve the same length in the LS7 vs the other engines? Cuz that may be why a 4" stroke works fine.
It's not that 4" or more is magically not reliable, it's the fact that it might be too much of a stroke on the stock sleeves of LS2s 3s 6s 1s etc.
Old Jul 15, 2011 | 09:31 AM
Texas_WS6's Avatar
You have the same issue with the LSX block. What everyone is telling you is with the corret rod length and piston design, there is no issue. If your builder is cared of the 4 inch stroke in the LS platform, leave him. He does not know the LS platform. There are thousand apond thousands of 4 inch LS engines running around making killer hp. I am one of them. They are reliable, very reliable if put tegether right. the 4 inch stroke is probably the most popular stroke when upgrading.
Old Jul 15, 2011 | 11:41 AM
Bill00Formula's Avatar
LS7s do have a longer sleeve. It is an issue but if it's properly setup (pistons designed for this) it seems to be ok. The gm LSX block has the same issue. I always wondered why they didn't make a slightly longer sleeve in the LSX.
Old Jul 15, 2011 | 06:46 PM
mike c.'s Avatar
I have diamond pistons with a 402ci. THE MORE CI'S THE BETTER.
