tqr3
Old Jul 14, 2011 | 08:55 AM
Rick364ls's Avatar
Default tqr3
does any one know if there is room to mill 317s on a stock bottom lq4 with tqr3 if so how much have not purchased cam yet so i cant check going better heads later just getting it together for now
Old Jul 14, 2011 | 09:26 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
I'd recommend a maximum of about .010" milling on that stock head with the TorquerV3. Unfortunately, the compression is still going to be pretty low I'd put a set of LS6 heads on your wishlist!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jul 14, 2011 | 10:15 AM
95FbFormula's Avatar
I had the same problem with my lq4 so I just picked up a cheap set of 241s to bump compression till I can get a better set of heads
Old Jul 14, 2011 | 11:39 AM
Rick364ls's Avatar
thanks guys appreciate your time
