Cam swap in 150k mi engine?
I'm planning to swap an LS1 into my 98 RS. I have a complete parts car to swap everything from.
What I'm wondering, is if it is safe to put a small cam (TR 224-112) in an engine with 150k miles on it. I will be adding LS7 lifters, LS2 lifter trays, new push rods, trunion upgrade, home ported oil pump, and a set of low mileage 241 heads (20k miles). Only reason for the heads is because the car smokes a little (very little) at times. I think it's a bad valve seal. The heads were given to me a while back and are in excellent shape. They have been sitting for a while, so i just figured I'd put them on the car.
The engine still has great power. Starts on the first hit of the ignition. I can drive the parts car, but it's been wrecked before and whoever fixed it didn't do too great of a job on it. None of the body panels on the front line up correctly, etc.
The LS1 will be put in the car so I can drive it until I finish building the LQ4 I have.
Car will also be getting a Performabuilt Lv2 4L60e when the LS1 goes in.
What would be a good stall to run with the TR224 cam?
Thanks in advance!
Derek
Good luck!
