when to tune your ls1???
Old Jul 28, 2011 | 10:06 PM
lippies's Avatar
Default when to tune your ls1???
hey guys.. i recently put a new exhaust system on my 02 trans am, pacesetter lt's,tsp y pipe, and a borla catback. im looking for opinions on when to tune your car.
it is kinda stuttering and bogging but i think because i switched the plugs to bosch and thats a nono!!! :/ any opinion is appreciated.
Old Jul 28, 2011 | 10:20 PM
z99ls1's Avatar
Restricted User
What do you mean when to tune it? did you take your egr off? Im guessing you did and your now in need of a tune...
Old Jul 28, 2011 | 10:36 PM
Tan327's Avatar
A tune makes these cars feel like they should from the factory, so any time is great and it's recommended now that you have LT's.
Old Jul 28, 2011 | 10:37 PM
garygnu's Avatar
cats removed?ls1 come tuned rich from the factory.a good exhaust would benefit from a good tune,if the cats are removed.consider a cam swap if it ain't your DD.
Old Jul 29, 2011 | 05:55 AM
crainholio's Avatar
Unlikely that is a tuning issue, the PCM will get the fuel trims back in the ballpark fairly quickly on its own if the engine is running right.
Ditch the Bosch plugs, go with the Delco spec ones and make sure your plug wires aren't damaged by checking w/ an Ohm meter.
After the engine is behaving, it's a great time for a tune.
Old Jul 29, 2011 | 08:09 AM
farmington's Avatar
get it tuned if you're not going to be making anymore changes in the near future.
Old Jul 29, 2011 | 04:43 PM
Cape T/A's Avatar
Tune it now, It will make a big difference. I would switch to some NGK TR55 plugs
Old Jul 29, 2011 | 04:52 PM
ryant13's Avatar
The 2002's do not have EGR. So you are okay with that point.
Old Jul 29, 2011 | 07:05 PM
BirdsSince16's Avatar
With just an exhaust swap, I'd consider a frost tune, especially if you plan on doing anything in the near future. Then get a dyno tune with some bigger mods like cam, etc.
Old Jul 29, 2011 | 07:19 PM
mike c.'s Avatar
When to tune?? I knew a guy who tuned a stock ls1 and got an extra 20hp. I know another who tuned a mild bolt on only car to get the most of it. Tune now,most dyno opperators will cut you a lower price if you go back for a retune due to mod changes. Mine always did.
Old Jul 29, 2011 | 09:31 PM
LilJayV10's Avatar
Good post.
Old Jul 30, 2011 | 05:23 PM
lippies's Avatar
thanks guys!! i have an offroad ypipe and after the installations its started kind of bogging a bit and my mpg is shitty as hell. im switching out plugs and wires tomorrow because my set of msd wires and ngk plugs just came in. my rpm at idle is also lower than normal. thanks guys for the advice. keep them comin...
Old Jul 30, 2011 | 10:52 PM
lippies's Avatar
whats a frost tune btw??
Old Jul 30, 2011 | 11:18 PM
LilJayV10's Avatar
Frost is a very popular tuner on the boards. I personally have never used him but dozens if not hundreds of people on here have. SloHawk is another.
