how to clean valves and C-Chamber?
Old Mar 2, 2004 | 01:17 PM
2001CamaroGuy's Avatar
Default how to clean valves and C-Chamber?
I removed the heads from my car and need to clean all the oil/carbon/crap off of the valve and the combustion chamber so I can inspect for any cracks and gasket match the combustion chamber to the larger bore. What would be a really good soap/claner/acid/etc... (not acid but you get the idea) to get this stuff clean?
Old Mar 2, 2004 | 01:24 PM
AZ Power & Sound's Avatar
Brake parts cleaner... stuff seems to eat away any kind of dirt or grime without hurting the surface!
Old Mar 2, 2004 | 01:25 PM
hmmm........I'll go try that
Old Mar 2, 2004 | 01:32 PM
2xLS1's Avatar
I took a set of Aluminum heads to the machine shop I used to use for my old school stuff to get them hot tanked. He charges $15/pair to hot tank heads. Only problem was his solution was not compatable with aluminum. He suggested a couple places in town that rebuild auto trannies as they hot tank the cases and would have the proper solution for the heads without damaging them. I cleaned up the valves on the wire wheel mounted on my grinder.
Old Mar 2, 2004 | 01:47 PM
LOnSLO's Avatar
A parts washer is about as good as it gets. 2xLS1 is right , do not get them hot tanked unles you don't mind them looking gray.
Old Mar 2, 2004 | 05:10 PM
found a shop with a parts washer
Old Mar 2, 2004 | 08:14 PM
Greg_E's Avatar
I had some valves, that had some carbon build up, that I wanted to remove. I used Valvtech marine motor decarb. It was the only thing that I tried that would touch the carbon. It comes in a spray can, so I sprayed it in a container, and let the valves soak in it with a lid on the container. The heavy carbon deposits Will crinkle up, and look similar to when you put paint stripper on paint. If you want to try the do it yourself approach, it works fairly well. It's probably the same stuff GM sells to spray through the engine to decarb the combustion chambers. One word of caution: This stuff should not be sprayed into an engine, and left for longer than the recommended length of time. The solvents will attack the seals in the engine if left for extended periods, and then you have BIG problems.
Old Mar 2, 2004 | 08:27 PM
where did you get that?
Old Mar 3, 2004 | 12:16 PM
big358's Avatar
Default check under your kitchen sink
I used EasyOff oven cleaner. It says not to use on aluminum, but I went for it. Kept dunking the heads in mild soapy water to minimize the exposure time. The oven cleaner blasted the carbon from the chambers in less than one minute with the aid of a brass wire brush, valves still installed.
Then on to the valves. Again, after dunking the heads repeatedly in the sink full of soapy water, I disassembled them, rinsed the bare heads and blasted them dry with the air nozzle. The EasyOff took longer on the valves but still worked out well, especially considering the price and convenience.
Wow, it's going to be an easy deal to port these babies. (317's) Just a light clean up of the casting flash/mismatch at the valve seat and a little work around the guide, the swirl ramp and the rocker boss.
Old Mar 3, 2004 | 03:43 PM
thats another good idea (EasyOff)........
Old Mar 3, 2004 | 04:20 PM
Cstraub's Avatar
Easy Off Oven Cleaner. ..$3.95. . .Walmart, K-mart, Krogers. . .
Chris
Old Mar 3, 2004 | 06:09 PM
Greg_E's Avatar
I bought mine at West Marine, but any marine supply store should have it. It's used to decarb two stroke outboard engines to keep carbon buildup out of the rings. If you can't find it locally, you can order it through West's catalog. GM also sells a similar product, for use in the LS1, but I don't know what they get for it. I paid $8-9 for a can.
Old Mar 3, 2004 | 09:15 PM
Scooter70's Avatar
I used the GM Top Engine cleaner and soaked the valves in it overnight. The first set, I put each valve in a separate 16oz red plastic beer cup and put 1/2" of stuff in. 45 minutes later, the cleaner had eaten the bottom of the cups off and made a mess on my bench..... oops!! Morale of the story: use a heavy plastic container because that shtuff is strong.
