Comp Rockers...........
Old Mar 2, 2004 | 05:17 PM
SSilver's Avatar
Default Comp Rockers...........
well I found some needle bearings in my oil today so I think I may just upgrade to some better rockers.
I was looking at the comp pro magnums but there are 4 different kinds
Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 5/16" guide plates, 1.75 ratio (Kit includes rocker arms, 5/16" flat guide plates, rocker arm studs & poly-locks)
Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 5/16" guide plates, 1.85 ratio (Kit includes rocker arms, 5/16" flat guide plates, rocker arm studs & poly-locks)
Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 3/8" guide plates, 1.75 ratio (Kit includes rocker arms, 3/8" flat guide plates, rocker arm studs & poly-locks)
Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 3/8" guide plates, 1.85 ratio (Kit includes rocker arms, 3/8" flat guide plates, rocker arm studs & poly-locks)
mods are in sig
Old Mar 2, 2004 | 05:24 PM
Blacker's Avatar
There is a GP on the Harland Sharp Rockers for $299.99
