lq9 or not?
Old Aug 4, 2011 | 09:17 AM
ssnovaturbo's Avatar
Default lq9 or not?
Hey guys,
So the motor is coming out of the 98 Z this weekend for heads, cam, intake, and basically a freshening. I have and lq9 short block ready to go and I'm curious as to what everyone thinks. Is it worth leaving the 5.7 out and going for the 6.0? Just wondering if its worth any gains. Heads are absolute speed stage 2 5.3's, 224r cam, ls6 intake, and 42lb injectors if needed. I would appreciate everyone's input as im not sure which one to go with.
Old Aug 4, 2011 | 09:20 AM
180ls1's Avatar
i have seen a few guys say that they picked up a 1/10th and 1 mph or so when they switch to a 6.0l you might get a tad more with it being an lq9 instead of a lq4. That cam should be very tame in that setup also.
Old Aug 4, 2011 | 09:23 AM
allout06's Avatar
stroke that ****** to a 408 and then you can answer ur question with a yes lol
Old Aug 4, 2011 | 09:31 AM
stroking it is the plan, just can't right now, just was curious if it would add enough hp to offset the added weight
Old Aug 4, 2011 | 10:01 AM
supersick99z's Avatar
If it ain't stroked yet I'd leave it out for now and just put it in later once it is
Old Aug 4, 2011 | 10:15 AM
aAZz's Avatar
Leave it out and build it while u have the ls1 in there then once the lq9 is built just put that sucker in
Old Aug 4, 2011 | 10:16 AM
aAZz's Avatar
U should go wit a bigger cam as well for the lq9
Old Aug 4, 2011 | 10:33 AM
Reed35's Avatar
For now i would keep the 5.7 in it, that way you can still drive your car around, while you are building a kick *** engine for it.
Old Aug 4, 2011 | 03:01 PM
Chaos07's Avatar
Thats what i plan on doing, Leave the LS1 and build up a LQ9 with a nice head/cam cambo
