Largest cam to pass emissions in CA
Camshaft - 232"/236" .585"/.598" 114LSA aggressive profile with a 2800-7000 RPM range, rough idle, for blower/nitrous applications
i hightly doubt that cam will pass, and besides, if your going to run a blower you dont need a cam that big. a 218/224 116, 220/224 116 will work just fine.
Some counties here are now looking at the OBD2 self diagnostic tests to determine pass/fail results. Not only does the car have to pass the tailpipe test on rollers at 15 & 25mph, it also has the gas cap test and OBD2 diagnostics. There are 5 tests (6 for EGR cars). I believe most of the available scan tools will show test status of the 5 or 6 different diagnostic tests. Many cars with aftermarket cams are not completing the "catalyst" test. This will result in a failed test and the car is considered "noncompliant". That means no registration renewal.
Somehow the aftermarket is going to have to get ahead of this or lots of people will be putting stock parts back on their cars every couple of years.
Any input about this subject is very welcomed................
Good luck,
Richard
Good luck,
Richard
Not really sure where reseda is located but i'll be staying with my girlfriend in vallejo. She said when they smog her car they just ( her words) stick this thing up the tail pipe of the car, i go have a smoke, and after about 10 min they tell me i passed and that's it. She did say they run the car, give you a print out, and the info is forwarded directly to dmv from the machine but that's it....no rollers or scan hook ups according to her. Maybe emissions testing varies from county to county out there, but this is all new to me since i never had to worry about anything like this before. Personally i think it's
but guess if you wanna drive there it has to be done.The aftermarket companies may just have to spend the money to get carb certification on all their products. This will cost them big money in the short run, but may wind up making them more money in the long run. As you stated if it get's to a point that they get so "tight" with the emissions laws that you can't even change the factory installed plug to an aftermarket one, then hope all these companies can afford to lose out when people start switching the cars back to stock. This will be especially true if all 50 states implement the emissions laws and get as strict if not more so than california.
Richard
Richard
. Not that i am condoning this, but how about one set of rules for everyone to follow? I think i'll give the cam i was looking at ( Camshaft - 232"/236" .585"/.598" 114LSA aggressive profile with a 2800-7000 RPM range, rough idle, for blower/nitrous applications) a shot since they only do the tail pipe sniffer test. Hopefully it will pass with a good tune. Thanks for the info Richard i appreciate it
. FWIW I saw a Berger ZL1 with 427ci engine sail past the local tests here. Those engines use cams with .600" lift and idle pretty rough. My guess is the duration @.050" is somewhere around 240º. I suspect the PCMs have been alterd by GMMG to change pass/fail criteria. I'd like to see more posted info about this subject though.
Richard
Richard
. Why bother going through all the trouble of putting a cam in a car and it idles almost like the stock cam i started with. Wonder what was altered in the pcm or anything else for that matter that made them sail through emissions? I myself would like to see more posted on how they acheived that cam to pass the stringent emissions out there and why no one else has been able to. I can't recall seeing any posts where anyone was running a 240 duration cam in California and it sailed through emissions no less! I'm sure there is a way to get these larger cams to pass, you just have to know what you are doing which is the name of the game with anything. Do you know anyone who's excellent with tuning these type of cars in the area? Being new to an area kinda sucks, but i'm sure i'll catch on to all the excellent shops out there
. BTW that ZL1 sounds absolutely fantastic with the sewer pipe sized exhaust system.
Richard
Richard
. I will definitly be looking him up when i get there. Hope mine sounds half as good through that 4 inch mufflex system as i know that ZL1 does...
. Take care and best of luck, will be looking you up when i'm ready for cylinder heads...
Check out www.norcal-ls1.com when you get into town to find out about the local tuners and any other info you might need.
