Isky cams
Old Aug 8, 2011 | 12:20 AM
supermaro's Avatar
Default Isky cams
Haven't heard many people running Isky cams on LS engines? Are they any good? I was thinking of running a custom grind from them, does anyone have an opinion on them or experience? Thanks
Old Aug 8, 2011 | 12:45 AM
A.R. Shale Targa's Avatar
Isky has been around FOREVER.... don't know if LS stuff is their best.
I've had excellant luck w/flat tappet circle track stuff but maybe you can
be the ground breaker here
Old Aug 8, 2011 | 01:06 AM
supermaro's Avatar
Thats kind of what I want to do. I guess the price is right (sponsor), and I just want to give it a shot. They're local and feel like giving someone else other than comp some business and credit .
Old Aug 8, 2011 | 09:13 AM
It seems that recently the limits of beehive springs have been getting pushed
w/.600-.620" cams. If your cam ends up in this range perhaps consider some
duals. Also the single most important valve event after deciding on the
duration for your app., is the Intake closing point. The sweet spot for an LS
is between 43-45 degrees after BDC.
Old Aug 8, 2011 | 10:36 AM
supermaro's Avatar
Thanks for the advice, I'm running dual springs good for .650 lift on my trickflow 215s. I'm about to call isky and talk to there tech department and check on that info.
