800 hp lq9 supercharged
The setup I want is-
lq9 408ci stroker
supercharger(looking for a used one around $1500)
Intercooler
forged pistons
lower compression around 8.5:1(need help on how to do that)
Meth injection
forged cam
boost gauge
boost controller
93 octane(can run 100 octane if necessary)
I'm guessing this will all come to around $6000. I know I'm a total noob so if I'm totally off tell me, but don't be a douche and just rant about it.
As a side note, I had a few questions.
Is an lq9 better or an ls1? I went with an lq9 because it's iron so stronger.
How do you lower compression?
Is 8.5:1 a good compression or should I go even lower for FI.
Does a supercharger reduce gas mileage even if you drive normal?
Could a t56 handle this much power?
What quarter mile could I expect if my car weighs 3100lbs with fuel and me?
Do I need a new driveshaft at this much power?
Thank you so much for all the help!!
FI gets very expensive because of everything that must be upgraded to handle the power. For example, if you still have a 10 bolt rear axle assembly, you'll most likely break it. The 9" or S60 rear you'll want to replace it with will be in the $3,000 range.
