How to calculate IVC @ABDC?
Old Aug 10, 2011 | 10:07 PM
ABQ99TA's Avatar
Default How to calculate IVC @ABDC?
I have my cam card but it does not show IVC @ ABDC @.006 which I understand is the number I need It does show it @ .050 to be 47. It Can someone point me in the right direction. Thanks for any help.
Old Aug 10, 2011 | 10:15 PM
ronnjonn's Avatar
I understand how, I'm just not sure I'll explain it clearly. Let's assume an advertised duration of 280 degrees at 0.006", and an intake centerline of 110 degrees.
280 / 2 = 140 - 110 = 30 + 180 = 210. 280 - 210 = 70. So, IC at 0.006" = 70 degrees after bottom dead center. The 180 is a constant, because that's how many degrees for the intake stroke.
Now, how about a 284 on a 111?
284 / 2 = 142 - 111 = 31 + 180 + 211. 284 - 211 = 73
Got it?
Now do yours for us.
Old Aug 10, 2011 | 10:17 PM
ronnjonn's Avatar
There is another method. Advertised duration - duration at 0.050", /2, plus the IC at 0.050"
Old Aug 10, 2011 | 10:26 PM
ABQ99TA's Avatar
Now, how about a 284 in a 111?
Got it?
Awsome man! Thanks a lot.
Old Aug 10, 2011 | 10:33 PM
ABQ99TA's Avatar
Sorry I didn't see the show us yours until now. Thanks again
285/2 =142.5 -109= 33.5 +180= 213.5. 285 -213.5 = 71.5
Old Aug 11, 2011 | 09:19 PM
ronnjonn's Avatar
You got it.
Old Aug 12, 2011 | 02:03 AM
PREDATOR-Z's Avatar
IVC= Sum (intake duration - IVO -180)
Old Aug 12, 2011 | 08:33 AM
ABQ99TA's Avatar
So are you saying the above formula is incorrect? Or this is just a different way to find it.
How do I find out the IVO on my card? Sorry for the ignorance I’m just trying to learn and make sure I get all my ducks in a row and know I have it right.
Edit: It looks to me that this might give me the IVC @.050? 47 but I was needing @.006
Old Aug 12, 2011 | 10:42 AM
PREDATOR-Z's Avatar
IVO= SUM {(Intake duration/2) - ICL}
These are true for whatever lift values you use. If you want at .006 then
.006 IVO= SUM {(.006 intake duration/2)-ICL}
