Head/cam/stall.... Help
Old Aug 11, 2011 | 09:25 PM
2500HD6.0's Avatar
Default Head/cam/stall.... Help
Ok my current set up is 100 shot plate kit, LTs, magna flow cat back, QTP Cutout, tune, lid, and a ton of suspension work.
I'm wanting to go with a head cam set up with a stall..... I would very rarely spray do to living in texas it's to hot to leave the bottle in my car and when I do spray I don't mind spraying less..... I was looking at the 2.5 heads and a 3200 stall but I'm not sure about what cam to go with. This is not my daily driver but it will be street driven. I do take a few 5 hour trips a year in it but thats about it.
my camaro has around a 140K on it but it runs prefect
Old Aug 12, 2011 | 02:43 AM
01ssreda4's Avatar
I'd go with a 3600 converter minimum if it was me. Then maybe something like a TSP cam, Futral cam, Vengeance, or something from Cam Motion....possibilities are endless.
Old Aug 12, 2011 | 11:28 AM
Kevin@Vengeance's Avatar
We can do a heads/cam set up with some trickflow 220 as cast, cam of choice, lifters, chain, pump, yella terras or trunions, all gaskets and seals, and we can add a stall in there. I would decide what cam you are going with and then select a stall speed. Give me a call here at the shop to discuss if you'd like. Thanks!
