Best cam for daily driver
Here's an article outlining different cams from comp, with increasingly more aggressive profiles for comparison. For me, a DD means you should me looking for the greatest margin across the entire powerband, not just what is delivered over 5500 rpm. I bought the XR265hr 54-424-11 with LS3 yellow springs in my 2000 WS6 am pretty happy with it, large, broad, mostly flat torque curve with a solid 10-15 HP gain from 1200 RPM upward, and still pulls well away from stock above 6000. It just depends what you want to accomplish and how you will drive with it. But if it's a DD, consider where you'll spend 99.995% of your time operating in the powerband.
http://www.superchevy.com/technical/...en3/index.html
I'd stay under a 224 duration or that EPS cam of 222/226 .
I went to a smaller duration more lift ( like the eps lobes ) it's a blast to drive.
Even the smaller cam has it's little quirks.
I have a good used 222/224 or 222/226 I don't remember. I think the lift is .56x.
I have the cam specs on my home pc. Pm me if your interested.
