ls6 cam power gains?
Old Mar 5, 2004 | 07:47 PM
tonyt123blue's Avatar
so if I can get a good deal on the ls6 cam what else should I try toput in while I am there spings pusrods double roller etc.
Old Mar 5, 2004 | 08:11 PM
DrkPhx's Avatar
You have to change the springs to at least the LS6 springs. Stock pushrods are fine as long as they are not bent. Timing chain is optional depending on miles and if you want to spend more time removing the oil pump to remove the stock chain. You will need new water pump gaskets, timing chain cover gasket, valve spring compressor (check the post by Larry in the Tools of the Trade section), crank pulley bolt, front seal for timing chain cover.
