broken valve cover bolt...
Old Mar 1, 2003 | 09:15 AM
black00WS6's Avatar
Default broken valve cover bolt...
I have a broken valve cover bolt in my head. It's in there pretty good too. (thought in-lb was ft-lb's..hey it was late) <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> I dont think "screw-out" will work, do you guys suggest anything else?
Old Mar 4, 2003 | 06:29 PM
99taws6's Avatar
Default Re: broken valve cover bolt...
you could try an actual extractor...The type that you drill hole, pound in and screw it out..
I have had success using a center punch and a hammer to walk it around and out.
If all else fails, drill it and put a heli-coil in it....
Old Mar 5, 2003 | 09:25 PM
BigBlack2002SS's Avatar
Yeah, just head to Sears and pick up a bolt extractor set -- I just needed one two weeks ago when I snapped off a banjo bolt working on a friend's old Subaru.
Set was $25. Came with hardened drill bits and matching extractors (5 of them or so?)
While you are at it, pick up a tap and die set if you don't have one, in case you ever mess up the threads on a bolt.
So handy to have around.
Old Mar 6, 2003 | 05:23 PM
black00WS6's Avatar
thanks guys, i'm going to try and take it out this weekend
