quick Porting question
Old Aug 26, 2011 | 09:36 PM
3rdCoastPowerSports's Avatar
Default quick Porting question
porting a set of 241 heads and was just wondering what i was supposed to do with the valve guides. am i supposed to cut them flush? push them back? seems like porting would scuff up the valve guides pretty good (not on purpose of course), or does it not matter and you just smooth the nicks out when your doing the cartridge rolls. also does the same apply to both intake and exhaust valve guides? thanks
Old Aug 26, 2011 | 10:06 PM
93Z2871805's Avatar
Veteran: Air Force
You could cut them down a little (I wouldn't necessarily cut them flush). Alot of people make a teardrop that flows to them to smooth the flow around the guide.
Old Aug 27, 2011 | 03:23 PM
thanks for the info.
also i was just wondering if you go too thin in some sports is there a fix like a aluminum high heat epoxy or something like that???
Old Aug 27, 2011 | 04:53 PM
chrisfrost's Avatar
Really the only way to repair spots that are too thin is welding more aluminum then machining back to stock and porting from there . But aluminum can be a little tricky to get it to burn in real good because of surface oxidation , if You know what You're doing it can be done successfully . If I can , whenever I weld a cracked head I first put the stripped head on the grill for half an hour , then weld it .
