timing chain ?
Old Sep 1, 2011 | 01:32 AM
wayne33's Avatar
Default timing chain ?
so i have a ls1 Im building to go in my 68 camaro. I going with ls6 top end, bottom end is stock replacement. im going to upgrade the cam, and the car might see small shots of nos.
i bought a true roller 9 way adjustable timing chain for cheap. here the questions:
1) is it just a replacement to install double roller chain and gears or what do i need?
2) or should i go with a ls2 chain? or do i need gears to use ls2 chain?
Old Sep 1, 2011 | 11:53 AM
NC98Z's Avatar
I've got a crane adjustable double roller on mine and it came with 2 shims for the oil pump for clearance. Most people rebuilding just use the LS2 chain and gear. Its the relacement part for the LS1 timing chain like LS7 lifters are the replacement part for LS1 lifters.
Old Sep 1, 2011 | 12:05 PM
ae13291's Avatar
i just went with a ls2 chain, used the factory gears, I think it would be better to add a ls3 style tensioner to the chain.
Old Sep 1, 2011 | 06:14 PM
Black 99 Bird's Avatar
LS2 chain here.
Old Sep 2, 2011 | 01:18 PM
Ronny_02_WS6's Avatar
Sorry to interrupt but Im about to get a new cam to replace the stock one, so just the ls2 style chain for about $45 with the stock gears would be fine???
Old Sep 2, 2011 | 04:25 PM
usafws6's Avatar
Id replace the gears too, but im sure youll be ok with just a replacement chain
Old Sep 2, 2011 | 05:52 PM
ae13291's Avatar
my gears were in good condition but i regret not replacing it
