Why no gains after head install?
Old Sep 15, 2011 | 02:44 PM
  #141
LeftySS's Avatar
Originally Posted by 1999Black_Z28
22 degrees
Thanks.
Old Sep 15, 2011 | 03:42 PM
  #142
Sprayed1998's Avatar
Does the a/f you command in the pe table seem to be spot on with your wideband? Or do you just adjust the pe table untill you get the a/f you want?
Old Sep 15, 2011 | 04:02 PM
  #143
LeftySS's Avatar
I sey me pe to 12.5 across the board and adjust the ve till i get what i want. Car was running a little rich probably 12.1 or so but i would think that is close enough to see some gain. But maybe not?
Old Sep 15, 2011 | 04:10 PM
  #144
So your not running your air meter?
Old Sep 15, 2011 | 04:13 PM
  #145
LeftySS's Avatar
No it wasn't perfect.
Old Sep 15, 2011 | 04:18 PM
  #146
Hmm, well all I can recomend would be to get you fueling correct. Get what you command, on a 346 I typically shoot for 12.7-12.9 and between 26-28 degrees of timing. If you are running 12.1 that is pretty rich.
Old Sep 15, 2011 | 04:27 PM
  #147
LeftySS's Avatar
Hey guys if I didnt use any thread sealant on the rocker bolts could that be some of my problem. The runners are ported so much that the rocker hole is cut into the runners. I noticed it when i got the heads but forgot when i installed them. That is probably why i have some oil on some of my plugs? Could the intake and exhaust charges be leaking there to?
Old Sep 15, 2011 | 04:43 PM
  #148
thunderstruck507's Avatar
Not sure if it would be your problem but I would definitely put sealant on them.
Old Sep 16, 2011 | 08:04 AM
  #149
LeftySS's Avatar
Well it has come to my attention that I should've shimmed the valve springs when i installed the cam. So once i get that done hopefully things will be good to go. I will still run a compression check to be sure and will be getting a dyno tune as well. So i hope that i was just getting a little valve float at higher rpm cause my loss of power.. (cross fingers)
Old Sep 16, 2011 | 09:11 AM
  #150
LilJayV10's Avatar
Yeah I think I have the same issue.
As with the rocker bolts yes that could be why you had some oil on your plugs. It also can be a source of a vacuum leak.
Old Sep 28, 2011 | 10:38 PM
  #151
LeftySS's Avatar
Just a little update. I have finally got the valve springs shimmed. Ended up shimming all of them .060 to get the installed height pretty close to 1.74 on all springs. That puts my max lift at about 1.152 which is about .060 to coil bind which is the advertised max from PAC for the 1518 springs, so I should be good on the springs.
Did a compression check on all 8 cylinders and they were all between 190-200 psi which I believe is pretty good. The check was done with the engine warm.
Took the car for a drive last night and it did seem to pull better from about 5200 to 6500 where as before it would kinda flatten out. Getting a dyno tune Tuesday, hope all goes well.
Thanks again for all the help.
Old Sep 29, 2011 | 12:23 AM
  #152
LilJayV10's Avatar
Good to hear. Let us know what it does.
Old Sep 29, 2011 | 11:25 AM
  #153
Yes keep us updated I think I'm having the same issue.
Old Sep 29, 2011 | 11:41 AM
  #154
LeftySS's Avatar
I will be sure to post the results.
Old Sep 29, 2011 | 03:43 PM
  #155
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Originally Posted by Darkman
Gears make a significant difference and render the before/after comparison meaningless other than to indicate the gear change is roughly equal to the head change.
Yes, agreed!!! Most ppl see a .5 drop on ETs in M6 from stock 3.42s to 4.10s which some ppl actually when trying to sell there car say it's like adding 50hp so their bolton LS1 they rate it at 450hp lol... don't add power, but can make drastic changes. Like me, I don't like launching hard as I hate breaking things so I went from 13.1s bolton tuned, etc. to low 12.4s lol... You go thru gears quicker so that's why you made your mods and didn't feel/see a difference. Go back with 3.73s or cheap find some1 with M6 car and get their stock 3.42s
Old Sep 30, 2011 | 10:47 AM
  #156
We are done with the gear debate. His slight change in gears is not enough to negate a set of professionally ported 243 heads. Period. Results with an automatic cannot be compared to a manual here.
Gears will still give an auto the same impression of power, but it translates to very little at the track. Especially in MPH where the OP should have seen a significant gain.
Old Oct 4, 2011 | 08:35 PM
  #157
LeftySS's Avatar
Ok here is the verdict. Went to Brett at XP Racing in OKC and he did a good job with the car. He didn't make a pull with my tune in the car but on the first pull after he changed some things the car made 388hp and I believe 366lb fts. Here is a graph of the final pull. What do you guys think?
Old Oct 4, 2011 | 09:40 PM
  #158
HTX's Avatar
HTX
That's great man. Now go back to the track and get some results!
