New Valve Spring Break-in Procedure?
Old Sep 20, 2011 | 04:04 PM
ZeeOSix's Avatar
Question New Valve Spring Break-in Procedure?
Putting a set of PAC 1518s in my stock Z06 (LS6). The springs didn't come with any instructions on how to break them in, but I've heard there is a preferred procedure to "condition" them before really getting on the motor.
I've heard that a couple of start-up and full warm-up cycles at below 1500 RPM should be done after new springs are installed. is this correct, or is there a better method?
Old Sep 20, 2011 | 04:07 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
I'd recommend a couple heat cycles, and if you used any assembly lube during the install (say on a new camshaft) an oil change after the heat cycles before letting her eat!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Sep 20, 2011 | 07:13 PM
chrisfrost's Avatar
Just curious does anyone know if a procedure similar to this is needed for new GM yellows ? Thanx
Old Sep 21, 2011 | 06:43 AM
toadzq8's Avatar
For any new springs I would use the heat cycle procedure that Matt talked about. I heat cycle three times, never had a problem with Manley, comp or PAC after doing this.
Old Sep 21, 2011 | 06:49 PM
ZeeOSix's Avatar
3 heat cycles it will be then. Thanks for the advice!
