Can you guys help?
Old Mar 8, 2004 | 03:34 AM
gus99ssm6's Avatar
Default Can you guys help?
So im getting of work, go to my car to turn it on.
Stepped on the clutch and the car turns on, and turns right back off.
It sounds like theres a leak somehwere b/c when it turns off, it sounds like theres a lot of air escaping somewhere tores the back of the manifold
whats the problem?what can i do to fix? I had to have a tow bring me home at 1 a.m .
any input is greatly appreciated.
Old Mar 8, 2004 | 03:39 AM
blk~2000~Z28's Avatar
What happened when you attempted to restart it? How did it run when you had it started? FWIW the noise you are hearing is possibly just your A/C or your AIR.
Old Mar 8, 2004 | 03:50 AM
gus99ssm6's Avatar
it was the same, i kept on turning on the car and it kept on turning off, same some of escaping air somewhere! i would rev it up and it would still sound like it wanted to turn off, it has to be a leak. i havent done anything to the engine..
Old Mar 8, 2004 | 03:52 AM
Are you getting a SES light?
gus99ssm6's Avatar
**same sound of escaping air, leaking some where, it wouldnt stay on, unless i kept on revin it up. what i wouldnt go anywhere.
Old Mar 8, 2004 | 03:53 AM
gus99ssm6's Avatar
i always have a ses light on cuz of my knock sensor.
Old Mar 8, 2004 | 04:01 AM
Well you may still be getting a code, the first thing I would do would be to scan the car again and make sure that the SES is indeed just your Knock sensor. If find that it indeed has other codes that will help you trouble shoot the problem easier. From what you describe it sounds like it could be a leak but since you have not touched the engine it makes this more puzzling.
