motor build questions
Old Sep 27, 2011 | 11:12 PM
outlaw-53's Avatar
Default motor build questions
I'm getting ready to pick up a reck 02 SS. My plan is to swap everything to my v6 camaro. Well I'm looking at building a mid 11sec car. I'm going be tearing down the motor getting the block rehoned maybe bore idk yet. My question is what whould be a great reliable set up to run a NA ls1?
Right now I'm looking at tsp there ls6heads with fast90/90tb im not sure about cam and keeping bottom end stock. also let you guys know if it helps my camaro already have 3.42 the SS has 3.23posi, Plan is to swap the drive train from the SS (trans, alum drive shaft) keep my rearend and add the posi. If you guys need anymore info to get me rolling tordes a beffup ls1 let me know. Thanks
