Swapping heads with ARP head studs
Old Sep 30, 2011 | 10:36 PM
silversrtman's Avatar
Default Swapping heads with ARP head studs
Im going to be swapping to a new set of heads and I already have ARP head studs in my motor. The first time installing them I followed blackcamaros how to and he says to pre stretch the studs by making three passes at 65 ft lbs. Do i have to do that again or do i just do the torque sequence when installing the new heads? Also do I have to worry about coolant seeping down the bolt holes or will the studs prevent it? Thanks in advance.
Old Sep 30, 2011 | 11:00 PM
garygnu's Avatar
you don't need to worry about restretching the studs.
Old Oct 1, 2011 | 02:43 PM
great, I was hoping not...Anyone have any idea about the coolant question i had?
Old Oct 1, 2011 | 02:55 PM
CraigS's Avatar
No need to worry about the coolant.
Old Oct 1, 2011 | 07:40 PM
Thanks guys eased my mind cause I'm a paranoid ****
Old Oct 1, 2011 | 10:29 PM
01ssreda4's Avatar
My studs were wet with coolant for the first couple of heat cycles. It had me worried. But they dried up and I'm not having any issues now.
Old Oct 2, 2011 | 09:00 AM
Howd you know they were wet with coolant?
